Equaliser Q - Width Problem
Irfan
Post by Irfan »
Hi all :)
I'm new to flowstone.
I've found a design problem in flowstones basic Equalizer mouse range/scaling. So you are able to go much farther than you need to. After the Q value goes down to 0.05 it starts to rise again as you continue to drag. This is clearly not right.
Here is a picture for better understanding.
https://www.dropbox.com/s/3vx3x1x0goeup ... 1.png?dl=0
If anyone know how to fix this please let me know.
Best wishes :D
Re: Equaliser Q - Width Problem
Hey Irfan,
welcome to the forum! Your observation is correct, altough I think nobody ever bothered to test for Q below 0.05. Anyway, here is a fix preventing Q from rising again.
ParametricEQ_fixed.fsm
(72 KiB) Downloaded 1006 times
Irfan
Post by Irfan »
Thank you Martin,
it's cool and it works great :)
can you please tell me how did you do that?
Best,
Irfan
If you navigate to the "Convert" modules,
Parametric EQ/GUI/Controls/Convert
you'll see the following conversion from W (width) to Q.
The formula is
Q = 0.05 + 10*(1 - W)^6
So when you drag W from 0 to 1 (in whatever units), Q decreases from 1.05 to 0.05. All good so far. However, if you drag further, since the power 6 is an even number, Q starts to increase again.
What I did is place a Max module after (1 - W) with one input not connected (same as if connected to zero) :
Irfan
Post by Irfan »
Thank you soo much!
Finally working how i wanted :)
