Sunrise - Sunset Calculator (Ruby)
DaveyBoy
Post by DaveyBoy »
So I found this Sunrise - Sunset formula on-line and thought it would be interesting to put it into Ruby, so I did, and it worked (eventually) :lol:
Here it is for anyone who's interested:
Sunset Algorithm with Altitude.fsm
(2.04 KiB) Downloaded 1226 times
Re: Sunrise - Sunset Calculator (Ruby)
that is cool !
8-)
DaveyBoy
Post by DaveyBoy »
Yeah I thought so too. It seems very accurate when compared to on-line calculators. Not too sure about the altitude though . . . I added that myself after a little googling, hope I got it right :oops:
PrDavid
Sunrise Sunset Calculator Ruby
Post by PrDavid »
The calculated times for sunset/sunrise are 4 hours later than they actually are. I checked the longitude/latitude coordinates for my zip code and they are correct. Any ideas?
DaveyBoy
Post by DaveyBoy »
Hi PrDavid
I think it may be something to do with this line here:
# 10. convert UT value to local time zone of latitude/longitude
# localT = UT + localOffset + dst
localtr = utr + 0 + dst
localts = uts + 0 + dst
I may be wrong but I think the local offset is the difference between your time zone and 0 deg longitude. this would be 1 hour for every 15 deg. Mine is set to 0 because I'm in the UK. I'll dig out the original formula I found when I get home from work and post it up. :)
