Weird Int prim behaviour for Pitch to Freq. WTF?
Help! I’m baffled by this!
Pitch to Freq issue:
If I use a green value from a knob to set a note number and put an Int prim on it, the pitch should increase in whole semi-tone steps but it ignores the value from the Int prim and operates smoothly with no exact intervals. Unless I attach just the output from a de-zip to the P-F input, then the Int works. This is the same for Martin’s Pitch to Freq converter.
See the note in the attached schematic.
WTF?
WTF?
- Green Int not working 1.fsm
- (127.69 KiB) Downloaded 960 times
- martinvicanek
Re: Weird Int prim behaviour for Pitch to Freq. WTF?
Works OK here: Take your schematic as it is, turn knob, get semitone schanges.
Thanks for checking this out Martin.
I was about to delete the post because I rebooted the PC and now it works. I'd previously closed and re-opened FS and the issue remained, so some corruption from FS seems to have stayed in memory even with the program closed.
It's the only explanation I can think of.
I guess I should have tried a reboot before asking for help
Thanks again.
Thanks again.
