Delay Looper
BobF
Delay Looper
Post by BobF »
BobsDelayLooper.fsm
(629.8 KiB) Downloaded 1152 times
THE DELAY LOOPER By BobF.rar
(311.14 KiB) Downloaded 1040 times
Hello gang,
This is a unique delay in that it is much more than just a delay, it is a stereo audio looper. Guitarist are probably the most familiar with loopers as the stomp box device you hit with a foot switch and it repeats over and over that riff you just played on your guitar. This looper is much more in that it has the capability of setting the START and END time of the delay time and then repeating that sound over and over. What does this mean, well say you had the phrase “my name is Bob” looped. By adjusting the start or end time knobs you could have it say “my name is”, “my name”, “is Bob”, “Bob”, and so on. Also many, many other effects can be had such as looped echoed delay, looped pitch delay, looped reverse echo, looped doubling, looped modulation effects, looped harmonies, looped ping pong effects, and even looped time effects.
Also I have NOT included a lot of presets as this Delay Looper requires a lot of hands on while you are using it. As example would be after a loop is created changing the Start and End times.
*** I can NOT stress enough that to really use this effectively you MUST read the PDF manual that I have supplied!
Have fun, I am sure there is a lot more to be discovered.
Cheers BobF.....
P.S., Many thanks to Martin Vicanek and Spoog (Rex) for their time, support, and great modules that they supplied. Also if I have forgotten someone’s module, thank you for it.
Please if you make any changes or find new uses PLEASE contact me as I would really like to see what you have done!
lalalandsynth
Re: Delay Looper
Post by lalalandsynth »
Cool will try it out !
