String Step sequencer
Hello members
another Helpful Tool
a 8 Step Stringsequencer with a Syncable Stringoutput
For a better understanding,
If usefull for send Initialstrings to MIDI or Other Interface it used more as one Initialstring to work.
The module [Sequencer.fsm] was created under "FlowStone 3.0.8"
I'll later add more tools as soon as they run error-free
Greetings Pali64
Greetings Pali64
- Sequencer.fsm
- Programable 1 ~ 8 Step syncable Stringsequencer
- (4.82 KiB) Downloaded 1335 times
We made Keyboard and Synthesizer for you
so all Poaple can kommunicate with a Language to all poaple understand
Music is the nicest work in World
Re: String Step sequencer
The upload won't open in 3.08. It was presumably made in 3.09...Pali64 wrote: The module [Sequencer.fsm] was created under "FlowStone 3.0.8"
Hello Spogg
So i was wrong attachement now i corekt it...
Thx for you Test
....Live long and peacefully.... ,\\//
Greeting Pali64
Sorry i work with 4 Different FlowStone Versions to test works wit all.Spogg wrote:.....was presumably made in 3.09...
Thx for you Test
Greeting Pali64
- Sequencera.fsm
- Version 3.09
- (4.82 KiB) Downloaded 1278 times
- Sequencer.fsm
- Version 3.08
- (4.79 KiB) Downloaded 1318 times
Yes that one opens
I would like to see it with some inputs and outputs to better visualise its function.
I'm not complaining but I think it always helps to see a new module demonstrated at least in a very basic way...
- lalalandsynth
This looks interesting, shame I have no idea what it does
Hello all
A other Version of this Sequencer
dos not use a external string input. it use a 8 Line entry mask for the 8 Strings, the No. of Pulse as Feedback.
and No. of Steps (1~9 = Last step is Exit and 1st Step is to Activate so 9 for 8 entries used)
The Checkbox on all Lines is to send a CR after string or not....
The module [8StepSequ.fsm] was created under "FlowStone 3.0.8"
Greeting Pali64
Greeting Pali64
- 8StepSequ.fsm
- module] was created under "FlowStone 3.0.8"
- (4.89 KiB) Downloaded 1241 times
Thanks Pali64,
but like Spogg said, we really need some input/outputs to fully appreciate this.
Keep up the great work, BobF.....
Hello BobF &Spogg & all others
Here is a Picture to i use this sequencerBobF wrote:T... need some input/outputs to fully appreciate this.
- A practic to use this String Step sequencer
- Example.jpg (114.34 KiB) Viewed 41031 times
Hello Pali64,
Thanks for the picture, but I am curious, why not just supply the fsm?
Cheers, BobF......
Cheers, BobF......
Hello BobF
Your Question:
The program in which I use it is very comprehensive and has also "Bug's" it would be nonsensical such a mamut program to disassemble to show only a few examples;) unfortunately, I am currently missing the time to "just as times "To make an application to show it as an example ... SORRY ...
But I would like to try it out later, if I have still other modules tested and you to the place of post here ...
Cheers and have a nice time ....
Your Question:
My answer:BobF wrote:..... but I am curious, why not just supply the fsm?......
