Stream Inspector v2
MyCo
Stream Inspector v2
Post by MyCo »
I've converted my "Stream Inspector" Debug tool to FS and on the way I just found a better solution. So now, here is Stream Inspector v2:
It counts the "events" inside a stream eg. if there is "not a number" or "infinite" which can cause serious problems. It can also detect denormals.
The new version, does the detection in pure x86 assembler, so even when there are denormals, they don't have a huge effect on the counter. It is also more accurate, so it basically can't miss one sample.
I've included a DC Lowpass, that tries to find the DC Offset. It does that directly in stream, and it can go down into denormals (it is supposed to be so)... so when there are denormals, there are CPU spikes.
Hope it's usefull.
streaminspector2.fsm
(10.73 KiB) Downloaded 1643 times
Re: Stream Inspector v2
Many thank, MyCo, that is such a useful tool to have! :D
Tronic
Post by Tronic »
Thx, started MyCo tool-box folder ;)
Walter Sommerfeld
Post by Walter Sommerfeld »
Yup - perfect... :D
keep on doing!
philton
Post by philton »
thx a lot Myco! very usefull :)
MyCo
Post by MyCo »
updated
there were some minor glitches with the Reset and Run/Stop button
digitalwhitebyte
Post by digitalwhitebyte »
Yes, it is needed.
