Baq EQ example
regressor18
Baq EQ example
Post by regressor18 »
Attached is a Baq EQ I did that closely emulates my Dangerous EQ in my rack. I used Plugin Doctor to very closely match my shelves to the hardware.
I would love for the community to take a look at this fsm and assist in optimizing. Under the hood, its very basic. 1 LS and 1 HS, both are using Martin's ZDF. Martin, if you are reading this THANK YOU for all of your work with Flowstone. I will say the HS at higher frequencies is experiencing Nyquist warping.
Lastly I did use an older beta of the 64 bit version to build this.
Matt
BaxEQ example.fsm
BaxEQ
(165.37 KiB) Downloaded 849 times
Re: Baq EQ example
regressor18 wrote:I will say the HS at higher frequencies is experiencing Nyquist warping.
Confirmed.
You could use my newer set of matched filters from here:
http://www.dsprobotics.com/support/view ... 76#p225010
These are supposed to handle cutoffs even beyond Nyquist. The DSP part is optimized ASM.
regressor18
Re: Baq EQ example
Hey Martin,
Thank you for the reply!
When I use those filters, the filter crashes with a gain value of 0. Any idea what im doing wrong?
BaxEQ example HS issue.fsm
(164.11 KiB) Downloaded 849 times
regressor18
Re: Baq EQ example
I think i resolved the issue. Can someone take a look.
BaxEQ example HS issue-Resolved.fsm
(164.14 KiB) Downloaded 836 times
Re: Baq EQ example
regressor18 wrote:the filter crashes with a gain value of 0. Any idea what im doing wrong?
My bad, thank you for pointing this out. Fixed in version IVb in the original post.
regressor18 wrote:I think i resolved the issue.
Not for Q = 1 and above, unfortunately. Please use my fixed version IVb.
regressor18
Re: Baq EQ example
Thanks Martin!
regressor18
Re: Baq EQ example
Hey Martin,
The HS is very unstable. If you move the gain knob back and forth it crashes the filter. Any suggestions?
BaxEQ example HS issue-unstable.fsm
(164.21 KiB) Downloaded 867 times
Re: Baq EQ example
No problems here with FS 3.0.8.1 or FS alpha. If you are using FS beta, that might be the problem.
