ruby faders horizontal
hallo, finally i did the faders also horizontal with a little graphical improvement and readout options which you can change easily, one is splitted into left and right area .... my programming skills are just for bloody beginners but nonetheless it makes lot of fun, hope you like it...
- rubyfader_horizotal.fsm
- (4.8 KiB) Downloaded 1231 times
- faders.jpg (56.04 KiB) Viewed 15079 times
Re: ruby faders horizontal
just updated the slider, you can set split now in the properties panel.
the properties panel is a hashlist now so it reqires just one ruby value input for all the properties which can be set to purgeable for smaller filesize after exporting, further in the draw methode it self is reduced to the minimum of calculations to have better performance when in use...
Nice man, thanks!
