(Ruby) Pen alignment fails ?
unkargherth
Post by unkargherth »
It seems that it works for the example in the manual ( page 170) but fails for other shapes, an arc in the example below
PenAlignment.fsm
(442 Bytes) Downloaded 1174 times
[i]Free your memory, .. with a free(). Like a pointer
Cast a pointer into an integer and it becomes the integer...
Cast a pointer into a struct and it becomes the struct...
A pointer can overflow... or can crash...
Be a pointer my friend[/i]
Re: (Ruby) Pen alignment fails ?
I would guess that is probably only works for closed shapes (i.e ones that you can fill with colour).
Post by Nubeat7 »
yes, i tried rect, round rect ellipse and pie - these are working but i didn`t check polygon and closed curve...
Post by Nubeat7 »
you could do a GraphicsPath - when you addArc it dont works but when you do close it with closeFigure it works!
unkargherth
Probably my initial guest/understanding on what means "inside" was mistaken. I supposed that Inside meant "within the limits of the area/rectangle defined, not in relation to a closed "DRAWN" shape
I was expecting this "inside" feature free's me to do again and again the boring "Area resize" that we got in SM for years
My mistake... I admit
